Tiller King Kutter tiller water in oil
   / King Kutter tiller water in oil #11
Tarps cause condensation.. I like to take old buckets and cut a notch out for the pto shaft, then flip em over the gearbox like a hat.
soundguy
I noticed my housing was full up. I had previously been using milk jugs with varying success, but today she gets the bucket. Thanks
   / King Kutter tiller water in oil #12
A bit of water in a gear case like that isnt the end of the world.
   / King Kutter tiller water in oil #13
   / King Kutter tiller water in oil #14
We have a tiller, got it used in 1978. Used it every year. Believe me, it's had water in it many many times. Still works fine. Never taken apart. A few times we tilled a 40 with it. But later we only tilled the house garden and not the truck patch part.
   / King Kutter tiller water in oil #15
IMHO I would think the moral ;of the story is to check you gear bo;x before you use it!
willy
   / King Kutter tiller water in oil #16
willy
Yes, and I hate doing that. I pop the hood and check fluids, but for the gearbox I just look for a leak and put my hand on the gearbox AFTER mowing to determine temperature.
That's how I found the water because the housing was unusually hot and I thought it was low on oil; it was actually high on water. I NOW prefer the bucket method, or a new storage shed, and I'll keep an eye out for a leak.
   / King Kutter tiller water in oil #17
Does it have a breather plug? if so.. that's how water is getting in.
Also.. if it's so hard to service.. I think I'd pry that cover off one more time and add a drain plug to it.. shouldn't take too long if you have a drill, welder/tap/die set.
guess there is no chance of making one of the lower bolt holes 'non-blind' ?? ( ie.. drill thru the casting into the end of one of the lower holes.. that way you can just remove that bolt to drain.. etc. .. will always have to pucky that bolt.. etc...
soundguy
Perhaps he meant 'spray brake cleaner' ?
soundguy
soundguy
Hey Soundguy good thinking. I used to talk to you on here. I was teddydo at the time. 15 years ago. Just wanted to say hello
   / King Kutter tiller water in oil #18
One of my lower bearing cap retention bolts looks odd as compared to the rest, I'm going to remove the odd looking one and see if it is actually a drain.
   / King Kutter tiller water in oil #19
We are so hot and dry here during the summer months - surprised that gear box oil doesn't heat up and evaporate.
Yesterday set new summer high - 104F.
   / King Kutter tiller water in oil #20
I imagine a free breathing gearbox would and should evaporate some moisture in summer months when used. The big problem is after use the if you have water (not moisture) in the oil, the water settles and depending on the amount, the lower bearing surfaces are sitting in water and potentially deteriorating.
2011 MACK CHU (PINNACLE) (A58214)
2011 MACK CHU...
(8) 2" x 27' , 5 Ton Ratchet Tie Downs (New/Unused) (A59225)
(8) 2" x 27' , 5...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
BUSH HOG DISC (A58216)
1R COLE PLANTER (A52708)
1R COLE PLANTER...
2010 SHOP MADE WINDMILL TRAILER (A58214)
2010 SHOP MADE...
