King Kutter tiller depth adjustment
   / King Kutter tiller depth adjustment #11
I just bought a King Kutter clone marketed by Agrisupply and it is exactly the same way. I have two more holes/depth adjustments that I could use to lower the tiller but the side gear box gets in the way. I just set it as low as it would go and matched it up the same on the other side. It seems to work fine. I can get till up a spot that is wrist deep and as pretty as you have ever seen.
   / King Kutter tiller depth adjustment #12
Another agreement. Shoes don't seem to matter much after first pass. I just have to learn the technique so my plot dosen't end up full of waves.
   / King Kutter tiller depth adjustment #13
I bought a County Line tiller from TSC last year and like your KK, the last set of holes I can't get to but like everyone has said so far, just till it a few times and it will till a little further down each time. Also play around with your top link a little. Mine actually tills deeper with the top link shorter.
   / King Kutter tiller depth adjustment #14
I agree with wveryone else here. Only purpose I see for the shoes is to set on when parked (unhooked) and keep soil from wearing into bottom of the gear case.
2002 Ford F-350 Crew Cab Pickup Truck (A50323)
2002 Ford F-350...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2010 CATERPILLAR CM1210106 ROUGH TERRAIN FORKLIFT (A51242)
2010 CATERPILLAR...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
Agway Bale Accumulator (A50515)
Agway Bale...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
