King Kutter tiller depth adjustment
   / King Kutter tiller depth adjustment #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
I just bought a used KK tiller and I am having trouble adjusting the depth. Looking at it from the tractor seat, the depth skid does not seem to line up in the bottom hole due to the gear case. I can get the right side to about 6" but am limited to about 3-4 on the left side. The holes just do not line up any way I try it. What am I missing?
   / King Kutter tiller depth adjustment #2
Just use it.
After you make a pass, the depth shoes aren't worth much anyway.
One will always be in tilled ground and going deeper and the other will be on un-tilled ground not going so deep.
you ain't missing nothin' ;) I just set mine as low as they would go (whatever holes lined up) and went at it.
this help?
Just use it.
this help?
That's what I have been doing so far. I thought there might be a secret handshake that I did not know.
   / King Kutter tiller depth adjustment #4
I agree, the depth shoes don't do much, I control the depth from seat using the 3pt lift. It is easy to even lift it up enough to just till some seeds in if you wish.
Mike
   / King Kutter tiller depth adjustment #5
Same here, set them at the lowest depth for tilling. One is usually bent out when I'm done anyway.
If it ever becomes an issue, I'm going to weld on brackets and add gauge wheels.
   / King Kutter tiller depth adjustment #6
Yep, me too..... Low as you can go. If you need to till deeper, till over it again.
   / King Kutter tiller depth adjustment #7
same here except mine does line up. I assume that the side that is lower then other is supposed to be in tilled and other riding on the untilled side.
Once you get it nice and fine, the depth shoes doesnt help anyways. it just disappears in the nice soft fluffy dirt.
   / King Kutter tiller depth adjustment #8
WOW!!! :shocked:
for once, we all seem to agree. :thumbsup:
:drink:
   / King Kutter tiller depth adjustment #9
I set mine as low as it would go also.
I still have the crate it came with and the depth shoes give me a level place to set the tiller on the crate up off the ground so it doesn't rust up when I am done thats about it! :thumbsup:
   / King Kutter tiller depth adjustment #10
We can make up something if you want...
:laughing:
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
Grasshopper 722D Zero Turn Mower (A50514)
Grasshopper 722D...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
2025 REDELIFT CPD25-XD4 FORKLIFT (A52141)
2025 REDELIFT...
