King kutter mower - painted belts spindles and fittings
   / King kutter mower - painted belts spindles and fittings #1
PistolPete
John Deere X590
So I just picked up my new 72” finish mower a few days ago and I’m getting it all set up. I get her hitched up, set the wheels, and then take off the cover to grease the spindles. Lo and behold, they’ve painted EVERYTHING. the belt, the spindles, the shear bolt and nut. The gearbox bearing. The ZERKS. Is this normal or did I get a messed up machine here?? Any recommendations for what I need to scrape off, and what I can leave? Will those zerks ever take any grease?
   / King kutter mower - painted belts spindles and fittings #2
Seems KK is getting messy more and more. At least mine didn't have the belt painted. The fittings . . . YES THEY DID.
I cleaned off the fittings with acetone because they stuck out far enough and then picked at it with a finger nail. Best NOT to mare up fittings with scratches.
As for the belt, just run it. If the pulleys got painted, you may need to figure out how to get the pain off of the bearings and not ruin them.
   / King kutter mower - painted belts spindles and fittings #3
Cheer up!
There is no primer, and likely no acid wash either.
Your paint will begin to chip off in just a few days.
   / King kutter mower - painted belts spindles and fittings #4
It's common practice to put a squirt of grease in the bearings during assembly and before it gets painted.
   / King kutter mower - painted belts spindles and fittings #5
On my KK Pro tiller (purchased 2017) they painted over the grease zerks. After greasing! So even over the extra grease hanging off the end. :) Not a major issue though... this is a piece of equipment, not a car. The paint has held up fine through a lot of tilling these past 4 years. The unit looks great.
Rob
Thanks guys for talking me down. On further inspection, the “moving” parts, while painted, were greased/oiled under the paint, so it peeled right off.
Got her all hooked up and lubed, and mowed my 6 acres this afternoon. Nice new tool!
Tiger Mowers 90in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 90in...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2012 John Deere 7130 (A50120)
2012 John Deere...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2006 Volvo VNL (A52748)
2006 Volvo VNL...
