King Kutter Finish Mower Spindles
   / King Kutter Finish Mower Spindles #1
mspaeth53
I have a 72" King Kutter finish mower that has the spindle bearings going out. I have replaced 1 of the spindles with a new one and would like to replace the bearings in the bad one. My question is, how do I take the spindle apart to get at the bearings?
   / King Kutter Finish Mower Spindles #3
I got a free kk finish mower and the spindles needed new bearings in them. I replaced the bearing with ones from a bearing supply house. One of the pulleys on top got loose and ruined the taper on top. I bought another spindle from KK and replaced the bad one. Many hours later the bearings in the new spindle gave out and I replaced them with new bearings and seals from the bearing house. It seems that the bearings in the spindles may not be of the same quality as aftermarket ones. If you reuse the old spindles I would use some locktite on the nut that holds the pulley on. That is what caused the pulley to come loose and ruin the taper. You have to dig the seals out to get to the lock rings. big dan
   / King Kutter Finish Mower Spindles #4
How do you get those keeper keys out? I have a bearing to replace myself in the next couple weeks.
   / King Kutter Finish Mower Spindles #5
I think they are called snap ring pliers
   / King Kutter Finish Mower Spindles #6
i KNOW BRINGING BACK FROM THE DEAD BUT ON THE KK/TRACTOR SUPPLY FINISH MOWER DECK ANY ONE EVER HAVE A PROBLEM WITH REMOVING THE SPINDLE PULLEY ?
ITS ON A TAPER WITH A WOODRUFF KEY CAN NOT GET THE PULLY OFF
   / King Kutter Finish Mower Spindles #7
You have to use a gear puller. Like this:
   / King Kutter Finish Mower Spindles #9
i have tried one. even applied a little heat,
Try again. And with tension on the gear puller, give the end of the gear puller screw one sharp blow with about a two pound hammer.
   / King Kutter Finish Mower Spindles #10
did that also even ran the wax down around the shaft. think the key spun up on this pulley . might have to cut this pulley off with the lathe to save the shaft.
does any one think a press will break this free? its a taper shaft and a woodruff key should pop off really easy with a puller
BROWN MPT-30 LOT NUMBER 63 (A53084)
BROWN MPT-30 LOT...
FAKE (A52472)
FAKE (A52472)
2025 JMR Tree Boom Skid Steer Attachment (A51691)
2025 JMR Tree Boom...
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
