Grading King Kutter box blade for JD CUT...
   / King Kutter box blade for JD CUT... #1
smokedtires
Lysander NY
I'm likely going to purchase a King Kutter box blade from TSC this weekend or next. King Kutter has 2 different models, the regular series http://www.kingkutter.com/WholeGood.asp?item=BoxBlades and their XB series http://www.kingkutter.com/XBProducts.asp?XBProd=48BoxBlade .
This is the reply I got from King Kutter when I asked which one I should get:
The 3 point spacing for Cat. 1 is 26" wide from pin to pin and 18" from
center of pin to top link hook up. We recommend between 20-30 hp for the
BB-48-Y.
If you have a Cat. O spacing which is 20" wide from pin to pin and 12" from
center of pin to top link hook up. If this is yours we recommend the
BB-48-XB which is recommended for tractors from 18-25 HP.
If your tractor is over 30 hp and Cat. 1 then you need a larger Boxblade.
My tractor is a 20hp 4100 model: what do you guys suggest I go with? Thanks.
   / King Kutter box blade for JD CUT... #2
Get the regular sized BB for your tractor. You do NOT need the XB series for your 4100.
   / King Kutter box blade for JD CUT... #3
I would get the regular one for the 4100. I have looked at the XB line and they are smaller in terms of volume of dirt it will support and smaller 3-point hookups for smaller machines. I think the XB line is a good fit for the X-series Deere where the hitch is much smaller than what you have on the 4100. Personally, I use a 4' traditional one on my 2210, no problem.
   / King Kutter box blade for JD CUT... #4
Good advice!
I checked out your website, you really need to reconsider parking that red thing in with your purdy tractor. Really unsightly!
/forums/images/graemlins/tongue.gif just kidding - looks great!
Thanks everyone, I had TSC order me the standard BB today so I should see it in a couple of weeks /forums/images/graemlins/smile.gif
RockyRidge, I'm working on getting a bigger place so the green family can all sleep together at night /forums/images/graemlins/wink.gif
   / King Kutter box blade for JD CUT... #6
I think that was a good choice. I purchased the BB model about a year ago and use it most of the time. I don't make huge demands on it, but it seems to hold up very nicely.
I have a 4310 which isn't that much different than yours. Hope you get as much use out of yours as I have and are as happy.
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
1999 Dodge Ram1500 ST Ext. Cab Pickup Truck (A56858)
1999 Dodge Ram1500...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2015 Infiniti QX60 SUV (A56859)
2015 Infiniti QX60...
2002 Henderson FSP Sandspreader (A55973)
2002 Henderson FSP...
