King Kong Teeth
   / King Kong Teeth #1
fishfactor
Monroe, NC
(2) 2014 CAT 299DXHP / FECON
I like to post my thoughts good and bad on products that I try. Hopefully it will benefit someone at sometime.
The previous set of teeth I ran on our Gyro Trac GT25 came from King Kong Tools. They just came off and here are the results.
Life - I was happy with the life at almost exactly 100 hours.
Cut - I was happy with the performance. Seemed to cut just as fast as Gyro Trac teeth.
But.... if you plan on using them, plan on switching for good. The tab on the back of the tooth is a little smaller than the Gyro Trac teeth and doesn't completely fill up the pocket. The extra space in the pocket gets packed full of debris. The debris is packed so tight that you need a hammer and small chisel or screw driver to get it out in order to put a Gyro Trac tooth back on, best case. I had a few pockets that were deformed. I had to use a die grinder with a small endmill to reshape the pocket so the Gyro Trac Teeth would fit. Luckily it didn't ruin the base. Those are no fun to change.
I had been warned about problems associated with the pocket/tab by a member on this board, but I already had them on the machine so it was too late.
So, if you decide to try them you will probably be happy with the teeth in general, but plan on making the switch forever. I would imagine that these problems would be compounded the longer you use them and eventually you would not be able to switch back without replacing all of the bases.
   / King Kong Teeth #2
Had the same problem with king kong tools on my Denis Cimaf head, but never became an issue. U need to try the BFS533P has carbide hard facing i got 175hrs out of the last set i used. They also keep a sharp edge than the hard steel tools, i sharpened them round 20-30hrs depending on the material i was grinding.
   / King Kong Teeth
I tried some of them spaced equally on the head. Cut was slower and when you factor all things in, the life difference didn't equal the price difference. If you don't like to sharpen they may be a good choice. I don't mind sharpening and like mulching a 24" hardwood in 10 minutes :)
   / King Kong Teeth #5
Fecon Can't Hang with a cimaf or gyro trac Head:D
   / King Kong Teeth
BUY A FECON, 600 HOURS ON ONE SET OF TEETH:thumbsup:
I've got one and get about 1000 hours on teeth unless they get broken.
   / King Kong Teeth #9
looks like a nice cimaf head on your rayco:laughing:, next time buy a fecon machine and it would have sold by now:confused2:
1998 KENTUCKY ENCLOSED CAR HAULER (A43004)
1998 KENTUCKY...
2000 INTERNATIONAL 9200 POLE TRUCK (A45333)
2000 INTERNATIONAL...
2018 Ford F-350 9ft Crew Cab Dump Truck (A44571)
2018 Ford F-350...
2018 MERTZ FRAC CHASSIS W/ENGINE &TRANS (A45333)
2018 MERTZ FRAC...
Ryobi Sliding Miter Saw (A44391)
Ryobi Sliding...
2018 WESTERN GLOBAL 8189 GALLON FUEL TANK (A45333)
2018 WESTERN...
