King cutter II tiller.
/ King cutter II tiller. #1
massey collector
Michigan
1938 Massey Harris 101 Or which one
I recently got a King Cutter II tiller, lots of wire wond on the shaft but finally got it all cut off. The back For lack of a better term splash panal is missing.
I would like to make one with some scrap heavy sheet metl I have but have no Idea how it is fastened across the rear.
Any one have any pictures of theirs they could show?
Thank you.
Al
/ King cutter II tiller. #2
What size tiller do you have? A 1/2" rod holds the panel on and the rod is full width of tiller. You can see the end of the rod is bent on one end. The other end the rod is cross drilled for a clip. The rod goes through 3 pieces of tubing that is welded to the panel. Tubing is welded on each end of the panel and one in the center to support the rod. My 5ft tiller panel is 58.5" on top and is 65.5" at the bottom. Panel is 13" tall. Notice the end tubing pieces extend past the panel ends maybe 1".
The tiller I got is a 5 footer I am sure.
Thank you very much for the pictures.
I take it thre tube the rod runs thru is on the under or back sides.
Al
/ King cutter II tiller. #4
Al
Yes it is. It just needs to be at the very top as the panel fits close the tiller frame and needs to pivot. If you need me to pull the panel for a back view, I can.
Thank you very much for the offer but I think i got the idea from the pictures you already posted.
Al
/ King cutter II tiller. #6
Also, the inside diameter of the 3 pieces of tubing is plenty bigger than the 1/2" rod that passes through it. That way it will always be free to move regardless of the dirt or rust.
I take it the rod is removable why my panal was missing?
I installed it on the tractor after remove a lot of wire wound on the cutter shaft. I tilled a small patch with it. So i had the third link short tiller tilled forward. then tried it with the third link long. Seemed to work better that way?
enhance
enhance
Yes I picked up a Ford (?)903 brush hog at the same time.
Al
/ King cutter II tiller. #8
I installed it on the tractor after remove a lot of wire wound on the cutter shaft. I tilled a small patch with it. So i had the third link short tiller tilled forward. then tried it with the third link long. Seemed to work better that way?Al
I set mine so the tiller is level when it is at working depth. There is less wear on the u-joints that way.
Thank you for the responce.
I will check that out once I can get it to working depth in this hard dry red clay.
Al
Thanks for the replys helped me figure things a lot.
So I just took it off my Kubota with a quick hitch and it kept wanting to tip forward on the top hook.
Mine doesn't have any feet and I see pictures of feet.
Could some one post a picture on where they mount maybe how long they are.
Al
/ King cutter II tiller. #12
This is the factory prop on the XB
/ King cutter II tiller. #13
I bought my tiller before they supplied the stands for them. I found trying to stand a tiller up safely was not happening without a stand so I made a pair. I don't use the skids so the stands bolt right where the 2 skid holes are with 1/2" bolts and wing nuts. Now it is sturdy and safe. I also have it sitting on roller plates so I can roll it around in the shop. The stands get the tines off the ground so I can rotate the workings too,
ruffdog, I like that set up but I do not have a shop with room to store it inside.
Al
2022 EZ-GO ELITE...
2012 HARDEEBILT 827PEQ6 EQUIPMENT TRAILER (A66091)
2012 HARDEEBILT...
2023 Dodge Durango AWD SUV (A64557)
2023 Dodge Durango...
TROY-BILT GENERATOR (A64553)
TROY-BILT...
2006 INTERNATIONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
1995 CATERPILLAR 140G MOTOR GRADER (A65053)
1995 CATERPILLAR...
