King Cutter Dump Trailer
/ King Cutter Dump Trailer #1
4sarge
US of A
Kioti DK 45s KL451S 72
Need a trailer for general use around the farm (hobby) to haul various items. Would you recommend this trailer?, Other trailers that you might recommend in lieu of this one. Pricing - where to buy - I'm located in Central SW Indiana.
/ King Cutter Dump Trailer #2
Looks like a nice item.
Bob
PS I know nothing about it, but have always been interested in getting one.
/ King Cutter Dump Trailer #3
Country Mfg in Ohio sells small dump wagons and trailers. Several of us here have them.
Country Manufacturing
Since it is truck shipped, will all of the shipped components fit in a standard 6X8 truck bed. You add the wood, assembly and hydraulic cylinder? Hydraulic cylinder - since I'm a city boy, where are these available, approximate cost - skill level needed for final assembly.
/ King Cutter Dump Trailer #5
Country Mfg ships on a pallet. 4x8 if I remember. You can call and ask. It comes with everything including the p/t wood. The 3x24 cylinder can be purchased from Surplus Center (part 9-4302-24) for $120. You are responsible for hoses and fittings. It is simple to assemble and directions are included.
There are several posts here regarding assembly and modifications. Do a search for Country Manufacturing or dump wagon.
/ King Cutter Dump Trailer #6
I purchased a Country Manufacturing tandem axle trailer last winter. I met the semi at a parking lot and we unbanded the trailor from the pallet and loaded it (piece by piece) in my 5x10 trailer with lots of room left over.
I am not mechanically inclined but I assembled the trailer in 30 minutes(make that 40 minutes because I actually READ the instructions). The wood was included.
I have never plumbed hydraulics. It took me about two hours to figure it out (along with some help from my Fleet Farm guy) and another hour to plumb it.
It works great.
/ King Cutter Dump Trailer #7
Has anyone converted these with a battery and a small hydraulic pump so that they dumped on their own without the tractor.
I need something that I can load up with the tractor and then haul where I need it and dump it with my pickup.
Loading it with the tractor, hooking it up and hauling it and dumping it and then hauling it back, unhooking it, loading it, hooking it back up, etc. seems like it would be a pain.
Just curious. Thanks, Nathan
/ King Cutter Dump Trailer #8
</font><font color="blue" class="small">( Has anyone converted these with a battery and a small hydraulic pump so that they dumped on their own without the tractor.
Just curious. Thanks, Nathan )</font>
Good questions! I look forward to the answers. I am looking into these dump trailers.
Bob
/ King Cutter Dump Trailer #9
It shouldn't be that difficult to do. I am sure Surplus Center has all the components you would need. Your biggest hassles would be to build a battery box, and mounting brackets for the pump and reservoir. Depending on your ground clearances, there should be sufficient room under the bed and frame to fab up whatever is needed. The brackets for the cylinder are already in place.
/ King Cutter Dump Trailer #10
If the dump trailer you are looking at is the King Kutter XB it is a pretty nice little trailer - not so sure it is quite worth the price though - although it appears to be the only one on the market quite like that in it's size.
I am pretty sure that the XB is manufactured for King Kutter by Pronovost - check out the P503:
http://www.pronovost.qc.ca/remra.html
http://www.pronovost.qc.ca/remhra.html
There are two versions - highway or offroad only.
I am pretty sure that pronovost also makes these trailers for Montana tractors - Montana has a trailer listed that sounds a lot like the P503.
Puma (a Pronovost subsidiary) also has a new trailer that might be what you are looking for:
http://www.pronovost.qc.ca/rempua.html
/ King Cutter Dump Trailer #11
</font><font color="blue" class="small">( If the dump trailer you are looking at is the King Kutter XB it is a pretty nice little trailer - not so sure it is quite worth the price though - although it appears to be the only one on the market quite like that in it's size.
)</font>
<font color="blue"> </font> Some nice looking dump trailers. I could not find any prices?
Bob
/ King Cutter Dump Trailer #12
I just saw one of the "off-road" type units at my local KK dealer the other day and the price was $1900!!
/forums/images/graemlins/shocked.gif *gasp!* /forums/images/graemlins/shocked.gif
/ King Cutter Dump Trailer #13
I priced out a Pronovost P503H a year or so ago and if I remember correctly it was in the $1900 vicinity. Tractor Supply can get the King Kutter XB trailer thru special order but I believe that one was still something like $1800. Northern Tool also carries the King Kutter XB and I think they want something like $1800 for it.
I cant find any pricing on the new small PUMA-347M trailer shown at: http://www.pronovost.qc.ca/rempua.html but my guess would be that it is a little bit cheaper than the Pronovosts because it has less steel in it and so forth.
2012 Ford F-150 Harley-Davidson Edition - 48k miles (A63689)
2012 Ford F-150...
1995 CUSHMAN TURF HAULER (A64280)
1995 CUSHMAN TURF...
INSPECTION (A65579)
INSPECTION (A65579)
Freightliner Columbia (A63689)
Freightliner...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
