Kinetico Whole House Water Filter
   / Kinetico Whole House Water Filter #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
does anybody have experience with this:
Untitled Document
seems to bee too good to be true, but I like the fact it uses no filters.
   / Kinetico Whole House Water Filter #2
It says no filters to change ever...but you probably need to add something to the unit once in a while. It probably backflushes itself through a mechanical timer (run by the water flow).
I have a Kinetico water neutralizer to balance the pH of our water (too acidic) and have been happy with it. I just need to add calcite every couple of years and the rest is easy. No electricity, no maintenance (other than adding the calcite). The product seems to be pretty good.
What is the final price of the unit? It says rent to own but how many months of $10 payments is that? Get a hold of the fine print from the installation company and check to see if there are any strange terms.
   / Kinetico Whole House Water Filter #4
My parents have had one for over 20 yrs. (actually on the second one now.)
It requires no electric and the unit itself does not require a filter. They did install a filter before the unit to help filter out iron and sediment. When the unit is installed there is a gear (on the original unit any how) on top that meters the water (based on water quality) once the predetermined amount of water passes through the unit, it switches from one side of the unit to the other. At that point it starts a backwash on the side it was originally on. There is little to no noticable loss of water pressure.
They do work. The company is based in Newbury, OH. (I have no connection with the company, just what I remember about the unit when it was originally installed.
Kurt
Nothing like shared personal experience - thanks everybody.
(APPROX 15) 2" X 6" X 68" TUBING (A54756)
(APPROX 15) 2" X...
10' FIELD CULTIVATOR W/ ROLLING BASKETS (A54756)
10' FIELD...
TRAILER AXLE (A54756)
2013 Vermeer V800G T/A Towable Vacuum Trailer (A53421)
2013 Vermeer V800G...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
