Killing Stump Roots
/ Killing Stump Roots #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I just recently cut a hedge apple (some people call them bodock or mock orange) tree in a fence row. I know from past experience that they have a strong tendency to sucker. I have previously cut limbs on this tree and the offshoots around the cut area are quick to return and quick to grow. I want the roots killed on this thing. Will putting roundup full strength on the stump kill it? If not, what should I use?
/ Killing Stump Roots #2
I cut lots of hedge apple/bodok/osage orange. I like Tordon for the stumps. Need a license for the "potent" full strength Tordon in KS., but the "ready to use" is fine for small amounts. I have also had pretty good luck with pasturegard. Generally only use the pasturgard because I already have it on board for other spraying I expect the round up will do it but don't have the experience with it on tree stumps.
The hedge is very good firewood but pops a lot and can damage some wood stoves due to high heat content.
/ Killing Stump Roots #3
I have recently used Roundup with pretty good results. I used it on a freshly cut chainsaw surface applied full strength with a paintbrush less than an hour after cutting.
I thought about drilling some 1/2" holes in the top surface, but didn't go to that much effort.
/ Killing Stump Roots #4
I have used diesel and salt after drilling a few 2" holes . =dead.
/ Killing Stump Roots #6
Whatever chemical you decide to you, you only need to coat the outer rim of the stump near the bark (on the cut surface). The thin Cambium layer just inside the bark layer contains the only cells that transfer nutients or moisture up and down from tree to roots. You waste chemicals by applying to the sapwood, pith, or heartwood. No need to drill into those woody areas either. This holds true for killing a stump.
When you hear of people drilling the woody areas, it is to apply other treatments to decompose the stump.
/ Killing Stump Roots #7
Round up sprayed imediatly after cutting will kill it as it will uptake the glyphosate (active ingredient in roundup, or the generic name if u will). This is as the mixed rate of 3oz to the gallon, there is no need to brush full consentrate onto it, all your doing is wasting chemical. There is a dosage rate for a reason. Thats one of the things they stress when you get your license, follow the labeled recomendations, not doing so is technically illegal as your not following its aproved use. Cause it says 3oz/gallon for brush dont meant that 9 will kill 3 x faster!
/ Killing Stump Roots #8
I've always cut a cross across the top of the stump and salted it ... seems to die and rot quickly that way?
/ Killing Stump Roots #9
There is no way I will be around to say I told you so or to have anyone tell me I was wrong, but I will personally guarantee the osage orange stump will still be there 50 years from now if it had any size to it. I set some osage orange posts in 1960, the year I graduated from high school, and just this year I noticed most of the bark has fell off the posts. No visible rot to the wood. About the only thing that will destroy them is fire.
Back on subject, my forestry rep has always recommended gettin the chemical on the stump, to prevent suckering, within minutes of cutting the tree down. Even if it does resprout folar spray will kill the sprouts. I spray hundreds of stumps a year and weather elements seem to have a big effect on how well the herbicides work. If it's dry I kill most, not as good during wet times.
/ Killing Stump Roots #10
Yep rotting the stump and killing are two different things. A rot resistant species although dead may persist for years. Thats where once dead and dry you drill some 1" holes and soak with diesel and then burn it.
If it is to dry it sometimes will not kill as the herbicide is not taken up by the plants as they are not very actively growing!
Thanks for all the good replies. The mistake I made was not putting the roundup on immediately. I did it the next day, so I may not be successful. If it starts to sucker, I'll try to spray them. Rotting the stump is not critical. It's in an old fence row and I just wanted the overhang out of the way so I can bushhog close to the fence.
/ Killing Stump Roots #12
Next day may or may not work, within minutes or hours before it seals itself is best. But you accomplished your goal. Like you said if it suckers you can hit those once a yr, or make a fresh cut on the stump and soak it with your herbicide.
2008 VOLVO VNM 6X4 T/A  DAY CAB TRUCK TRACTOR (A59911)
2008 VOLVO VNM 6X4...
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
2025 Kubota L4060D 42HP 4WD Utility Loader Tractor (A61572)
2025 Kubota L4060D...
7'' PALLET FORK EXTENSIONS (A61572)
7'' PALLET FORK...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
