killed my case 580c
/ killed my case 580c #21
if its turning at the crank shaft pulley its turning at the flywheel i have never seen one brake a crankshaft and the front pulley turns and the flywheel dont it will have to be a really clean brake i would put the starter back on and jump the soleniod a cross the two large prongs and see if it will start u dont even need the key on i believe that machine has a manual kill if i am thinking right i know a 580 b does
got it running! i was playing around with it, and replaced the positive terminal clamp. the old one fit kind of loose.
touched the starter, and it fired right up. i don't know why it failed when it did or why the engine stopped because of a faulty battery terminal, but i am so glad it did, because it saved me a rebuild.
I limped out of the woods where i was working, got it on a level area and shut it down. i have to degrease the entire front end and check all the fluids, and hopefully I can finish my project.
Thanks a bunch for your help.
-matt
/ killed my case 580c #23
I'm a little late to answer but if I had been earlier I would have told you the engine is fine.
I had a Chevy van that my employees never checked the oil on AND IT LEAKED. They pulled up one day and it was knocking like a machine gun.
The mechanic said it was gone. I filled it up with oil, it knocked, then stopped and I ran that vehicle for another 100K miles.
I can go on and on about running vehicles with NO oil but it's not as bad as people tend to make it out.
Here this explains it better than I ever could. This engine had SAND in it and NO OIL.
Water and Silica sand
YouTube - Volvo Cash for Clunkers Engine Disabling
YouTube - Cash for Clunkers: How to destroy an engine.
/ killed my case 580c #24
You might want to change the oil filter a couple of times in case it scraped up any metal filings inside. I think you said it did run dry on oil at first right?
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
Unverferth RHD1645DG-36 Rolling Rarrow (A63116)
Unverferth...
2025 Swict 72in. Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2015 Ford F750 Dump Truck (A64047)
2015 Ford F750...
6 1/4 INCH OD 90 DEGREE ELBOWS (A63569)
6 1/4 INCH OD 90...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
