Key won't turn in Ignition
   / Key won't turn in Ignition #11
Lots of good suggestions OR just spend a few bucks, replace the ignition switch and be done.
   / Key won't turn in Ignition #12
If one of the tumblers in the ignition lock has broken or jammed, the key will not turn the lock.
After the oil up you could use air to blow it into the lock. Not required with WD40.
Might polish up the key with some steel wool.
WD40, It worked
Thank you all..... You really saved me. WD40. Sprayed it this morning, it didn't do anything. My husband walked by it this evening and reach over and turned the key and it started right off. So glad to have my tractor back.
   / Key won't turn in Ignition #15
I believe the dealers response regarding 'replacing the battery' was due to them misunderstanding as "key not turning the engine over." That is partly their fault for not asking enough of the right questions to fully comprehend your issue.
Now, WD40 is not a long-term remedy for your ignition switch. Force some di-electric grease (or petroleum jelly) into the switch and insert the key. Do this a few times to lubricate the tumblers.
If your tractor is stored outside make sure rain cannot fall on the switch as it will dribble down the key and into the switch causing a recurrence of the problem.
Depending on your location and dealer proximity it would be worth buying a new switch assembly and having it on the shelf in case the problem returns. You now know you have a suspect switch which will need replacement sometime. Buy 2 x new keys at the same time. (Worn keys can ruin a new switch.)
:wrench:
Thank you good suggestions. I appreciate it.
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
2019 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP3KFA58619, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2019 Ford F-150...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2015 INTERNATIONAL DURASTAR 4300 (A58214)
2015 INTERNATIONAL...
2017 BX2680 Sub Compact Utility Tractor (A56435)
2017 BX2680 Sub...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
