Kerosene?????
   / Kerosene????? #1
Kuboy
Kubota B7610
Hello,
After pumping 5 gallons of kerosene at my local Ice Cream store I realized it is kerosene for home heating and not Diesel. If I use this in my tractor will it kill it? I have no other use for it.
   / Kerosene????? #2
Kero is often mixed with diesel during winter if there is not enough winter additive in it. You should have no issue putting the kero in your tractor. Just try to keep the mix 50/50 or less kero.
   / Kerosene????? #3
it'll work..
   / Kerosene?????
Thanks for the info Break, I'll just add a little at a time...and go buy some Diesal.
   / Kerosene????? #5
Kero is lacking lubricity but you can add outboard 2 stroke oil.
I mistakenly put 4 gallons of gasoline in my Dodge Common Rail diesel then added 2 quarts of 2 cycle oil, it never missed a beat.
2 Stroke oil also quiets my 1st & 2nd Gen Cummins & it runs smoother.
90cummins
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
2007 CHEVROLET SILVERADO TRUCK (A54756)
2007 CHEVROLET...
Frontier WR1008 - 8 Wheel Pull Type Hay Rake (A55218)
Frontier WR1008 -...
2017 Freightliner M2 106 TMA Attenuator Truck (A52377)
2017 Freightliner...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52705)
2014 CATERPILLAR...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
