Kerosene - what is it?
   / Kerosene - what is it? #1
dknarnd
Columbia County, PA
JD1010, JD B, TC40A (new)
Where does K1 clear fall in the diesel fuel catagory?
This summer I tore down an old mobil home that was on my property so I saved the fuel from the tank, I was having the tank filled with Kerosene. I drained the tank into a drum and the kerosene is pink color, is this just dyed K1 kerosene? Can this be used in the tractor or should it only be used in a mix with fuel from the pumps?
I also use kerosene in a salamander heater for heating my garage but I have about 70 gallons of the stuff to use. Although I also kept the furnace from the mobil home and plan on installing that in my garage for heat but still I won't use that much kerosene in a year.
   / Kerosene - what is it? #2
If there's no sediment or water, burn it as diesel fuel. You should probably add lubricity by using Power Service etc.
Last year when diesel was $3.29 I noticed a seasonal spring closeout on odorless kerosene heater fuel, $1.99/gallon, at Home Depot. I bought a shopping cart load of gallon jugs.
Kerosene has less heat/gallon and there was a slight noticeable decline in maximum hp. The tractor ran more smoothly than usual. I think that was the tank where I also used a tiny can of 50:1 2cycle oil as an additional lubricity additive.
   / Kerosene - what is it? #3
Kerosene boils just lighter than diesel.
Vermonters have used as much as 50/50 kero/diesel in the winter for flowability at low temps. I've put in as much as about 1/3 into a tank of diesel fuel on my 4010 so far.
Ralph
   / Kerosene - what is it? #4
K1 is approximately the same thing as #1 diesel and Jet-A. Most refineries make one product that meets the specs for all three and can be sold as any of them.
Without knowing the pedigree of the pink Kerosene, I would use it in the salamander, not a diesel engine.
   / Kerosene - what is it? #5
As cp1969 said, K1 is about the same as #1 diesal and Jet-A fuel. A low lubricity fuel so don't use it full strength in a diesel engine unless you plan on changing your injectors soon. I would go a max of 1/3 kero to 2/3 diesel.
   / Kerosene - what is it? #6
Going the other way with this - what happens if you run off-road diesel in a kerosene heater? Does it put off smoke or heavy fumes?
It would sure be nice to fill my kero heater out of my diesel tank rather than running to the store to fill 5 gal cans.:)
   / Kerosene - what is it? #7
I ran diesel in my salamander heater, ONCE. Fumes were strong enough to drive me out of the building. On K1 the fumes were almost unnoticeable.
   / Kerosene - what is it? #8
Diesel in a kero stove would smoke terribly. If you use off road diesel in a catalytic (no vent type) kero stove, you'll likely foul up the catalyst that converts the CO to CO2.
Ralph
My brother lives near the capital of NY and has had problems with fuel gelling up in the winter so he is now missing about 20% to 40% kerosene in his fuel for winter use. So he is in the ball park of being safe at 20% - 30% but 40% is starting to push it. I'm going to stay at no more than 20% and see how it works this winter. Although I still don't see the need in doing this because the stuff out of the local pumps is being run all winter by vehicles without mixing kerosene in it. Why would it be different in a tractor, unless it is the use factor where the vehicle is being used every day but my tractor may sit for a few weeks at a time before using it in the winter.
   / Kerosene - what is it? #10
I have a DESA 170K BTU Reddy Heater I picked up from Lowes last year that I'm using in the polebarn. It's rated to use kero, No. 1 & No. 2 Diesel/Fuel Oil, Jet-A or JP-8 fuels. I've been burning premium off-road diesel directly from the tank I fill my tractor from and don't find the fumes or smell any worse than the more expensive K1 kero that I picked up when I first got it. Of course, there's no ceiling in the barn at the moment and it's slightly over a 3000 sq. ft. area. Maybe if it were more enclosed and smaller it would be more noticable.
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A54607)
2006 KENWORTH T800...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
