Kerosene Ready Heater/Salamander
/ Kerosene Ready Heater/Salamander #1
Lloyd_E
Veteran Member
South Shore Nova Scotia Canada
2008 Kioti DK 45 sc
Went to fire it up. No go. Took apart. Lots of spark - actually use a spark plug... go figure.
Not drawing fuel. About half a tank. Fan works. Could the impeller have dried out?
Also, anyone know of a manual or can you explain the two plastic adjustment screws on the
fan/pump end of the unit.
TIA
Found their site... prices are actually very inexpensive.
Anyone ever repair these things?
/ Kerosene Ready Heater/Salamander #3
check your rubber pick up hose, mine had a small crack in it a couple of years ago and would not pick up the fuel. Replaced the hose and it works fine. :)
edit: it may not have been a pick up hose.
/ Kerosene Ready Heater/Salamander #4
I've never worked on my Dayton 110K btu unit, but I expect any time now, at 12 years old though, it has been pretty reliable.
Sorry I cant help you.
I may be asking you when I go to take mine out and it's a no go :eek:
They sure come in handy when you need them.
JB
Thanks all. I believe this thing is 10-12+ years old. Can't remember when I bought it.
Worked perfectly up till now. First time cleaning or maintaining it. Switched to diesel last year
based on info from TBN. Less fumes - cleaner burning.
Will keep ya posted. A few reference sites for you.
Desa Parts - Desa Service Manuals
Reddy Heater pump pressure instructions - YouTube
Reddy Heater Parts Sales..Online..Mr, & Reddy Heater Parts, Master Heater Parts, DESA heater parts central, Pearl Abrasive Hexplates and Pearl Abrasive Hexpins, Stow mortar Mixers, Stow concrete mixers, Stow plaster mixers, Stow mixers for constructi
/ Kerosene Ready Heater/Salamander #6
TIA
About those 2 adjustment screws.... 1 is a port to screw a pressure gauge into. Most are 1/4" NPT. The pressure is fairly low ( about 4-7 psi).
The other is the screw to adjust the pressure. Clockwise increases pump pressure and vice versa.
I agree with the fella that said a cracked rubber hose could potentially cause your problem. I had the same problem.
-Jay
