Oil & Fuel Kerosene diesel mix?
   / Kerosene diesel mix? #31
Dyed Diesel and heating oil comes out of the same compartment on trucks here, just billed and taxed differently, so probably the heating oil follows the seasonal grade changes.
   / Kerosene diesel mix? #32
Around here all heating oil is #2, if you want #1 or a blend you have to specify it.
Outside above ground tanks are normally kerosene or #1,
buried or in the basement tanks are #2.
#2 costs less and has more btus.
   / Kerosene diesel mix? #33
Might just want to make sure your heating oil is ULSD, most dyed off road #2 sold now is, but if not and it's being used in late model tractor with DPF or DOC and has high sulphur content that might be a problem down the road. Either way it should be blended with #1 or treated to prevent cold weather gelling.
   / Kerosene diesel mix? #34
Is the difference in BTUs noticeable in engine performance? Is it worth trying to have the more fortifiied grade whenever possible?
   / Kerosene diesel mix? #35
In a tractor or a truck you will notice the consumption increase,
unless you are using all the available hp not so much the hp loss.
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
1839 (A57192)
1839 (A57192)
2014 Dodge Charger Sedan (A55853)
2014 Dodge Charger...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
