keltec 380t
   / keltec 380t
I won't carry any gun c&l unless it's a sig with a decocker... everything else has nothing in the tube till after it's pulled.. thus.. I like to carry my sig as much as possible.. the ultimate point and click interface.. no need to rack a slide or thumb off a safety in an emergency...
soundguy
Glad to hear your incident free range report soundguy, that's what you need to have confidence in what you carry.
No, the 238 doesn't have a decocker and it is only SA, I was thinking manual decock but that probably wouldn't be the best way to carry it.
The safety is not gonna trip to fire to easily, I felt them in the store they're pretty firm, but I still don't want to carry C& L in my pocket, definitely prefer DA now.
Watch those video reviews from Nutnfancy they're pretty good and he shows all the comparables.
I researched all the major players in the .380 market pretty thoroughly the past couple of weeks, though I guess it didn't help me make the best choice :Mad: spending 2X what the others cost and have such problems.
I composed a letter to Kahr today, I laid it on pretty thick and heavy about how disappointed I was with my new .380 and how maybe I should of bought a KT or Ruger.
Not sure what I want from them, get a perfectly functioning .380 back, get a refund, maybe send me a PM9 instead.
One thing I know for sure I still want a pocket pistol that I can count on.
   / keltec 380t
might also add that the only failure I've ever had on my p230 was a failure to fully extract once.. it was a rem/umc case that split and extracted about half way and stuck.. I used a dowel rod down the barrell and it came out with no mor ethan hand pressure.. brass was cracked... got a free box of ammo from umc out of that complaint letter and the case i mailed back to them...
soundguy
   / keltec 380t #33
soundguy
The ultimate carry gun for me, would be for Sig to spend some time on the P232 and make it smaller and lighter so it could fit in a pants front pocket. I think they would hit a homerun in competing with the Kahr, Keltec and ruger mini 380's.
Leave the controls exactly the same DA/SA, decocker and heal clip mag release. For double tapping, I really like a DA/SA trigger.
   / keltec 380t
they could sure par down the hand grips a bit.. they are rather large.
it's actually a light gun for it's size.. i think they did that to control muzzle rise on shots.. still.. it's one of my favorite guns.
soundguy
   / keltec 380t #35
I think the problem is there is just no room for all those features in a smaller package. You should see the minuscule parts in the Kahr, the spring that keeps that slide stop down is about as thick as a hair, (which may of been the main cause of the feed problem) tiny little Torx head screws that I've seen larger in a wrist watch.
The Walther that I said I didn't like had all the features you want, decocker, DA on the first pull from decocked, SA after that, time tested reliable etc. but it's a bit to large and all steel heavy to carry in your front pants pocket. So my thinking is if I'm gonna holster a heavy 6 rd .380, might as well carry a baby Glock with twice the capacity and higher cal. same weight.
   / keltec 380t
Then you get back to the too big to carry comfirtably argument.. and then.. not carrying.
The p3at, so far as i can tell from hitting gun shows nearly every weekend now, is the smallest frame 380 you can get that carries 6 or 6+1 shots.. that happens to pretty much make it one of the easiest to conceal too.
soundguy
   / keltec 380t #37
Well I may come back to look at KT, right now my hands are tied. They will receive the gun tomorrow, I want to see what they say.
When I first looked at KT and Ruger I thought they were almost to small/light, like I'd break it if I sat on one in my back pocket. The Kahr definitely felt a tad more substantial.
I wont look back at the exorbitant Price tag with much regret if they get it running right, if not then it's a lose/lose.
   / keltec 380t
I sit on my keltec every time I go out into a place that allows CC, and is not prohibited.. It is in a sqaured off wallet ( nfa legal) wallet holster... neary a problem after 3ys on the p32..and non thus far on the p3at.
soundguy
Scrap Water Tank, Asset# 61 (HAS HOLES) (A59076)
Scrap Water Tank...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
(4) 12" I BEAM - APPROX. 40' (A58374)
(4) 12" I BEAM -...
ONE NATION UNDER GOD CONCRETE STATUE (A58374)
ONE NATION UNDER...
NEW IDEA 1 ROW CORN PICKER W/HUSKING BED (A52708)
NEW IDEA 1 ROW...
1995 FORD LTL9000 FLAT TOP DAYCAB ROAD TRACTOR (A58375)
1995 FORD LTL9000...
