kelley b30j 3 pt back hoe
   / kelley b30j 3 pt back hoe #1
joehinvt
ashtabula oh, north western ohio
85 ford 4610
anyone one here have a picture of the circuit relief valve disassembly on a b30 hoe? i seem to have no power the the dipper cylinder under load, ie. when digging. all other circuits seem fine and the dipper powers OUT fine its just when i try to curl it in. the owners manual says to clean the circuit relief valve..... not real clear on directions tho....... anyone able to help me?? im not a hydraulics pro!! psssss its a b30F not a j
   / kelley b30j 3 pt back hoe #2
I don't have a Kelly hoe, but I have seen a few of these old classics.
All hoes have a main relief valve, and some have RVs in the work ports.
These latter RVs are "shock valves" that protect each circuit. You can
see if you have them on each work section of the control valve stack. Do
you have them?
If so, RVs are not too complicated inside; they consist of a spring, and
some washers, plus a piston or ball.
Since other circuits work OK, your main RV seems OK.
yeah i figured the main rv was fine because i have lots of digging power to all circuits just not the dipper power in circuit. power out is fine. im just nervous taking this apart because im not even sure which is the RELIEF valve on the setup. manual shows three of them. and i think theres one under the dipper circuit valve.dont wanna take it aparts and have parts go flying or something!!:confused2: lol
or how about a generic pic or diagram?????? i have searched the forums for hours and cant find any!
2012 Dodge Grand Caravan Van (A50324)
2012 Dodge Grand...
2015 Caterpillar D6K Crawler Tractor Dozer (A50322)
2015 Caterpillar...
Wood Fence Posts (A50121)
Wood Fence Posts...
2019 Ford F-250 XL (A50120)
2019 Ford F-250 XL...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
3pt Roller (A50121)
3pt Roller (A50121)
