Keepint palm trees alive in winter
   / Keepint palm trees alive in winter #1
RSKY
Elite Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
Anybody have any ideas on how to keep Majestic Palms alive thru a Kentucky winter? I have five that are about six feet tall. The tags said they would not survive below 40 degrees. From what I have read they need a lot of light if kept inside.
I am open to suggestions.
RSKY
   / Keepint palm trees alive in winter #2
Not sure how many trees your talking about but maybe some green house plastic cover with a heat source like lights to keep the temp above 40 deg.
   / Keepint palm trees alive in winter #3
Are they in pots?
Cause if they're not, you have an up hill battle.
I have done so many times and it's very common to see people here trying to keep sensitive plants alive through a cold snap in Florida.
I no longer try to beat mother nature and now I plant what she wants me to and my life is much easier YMMV.
Where you live I don't think you would see success using the techniques commonly used here. The sustained cold temperature can only be kept off the tree using insulation and some type of heat source. I suspect you have frost down to at least 12" too.
If they are in pots you might could move them into a warmer place and hope for warmer weather...
The really tough part is making it through a few mild winters by going through a lot of work, and then one bad winter and you loose it all anyway.
   / Keepint palm trees alive in winter #4
Around here, they wrap the trunk, top to bottom in plastic, and use a light bulb to supply a little heat. Seems to work. I tried one and just mulched heavily with straw. It died a slow death.
   / Keepint palm trees alive in winter #5
Lots of windmill palms here in the Pacific North West
image-4271093523.jpg .
I think they are the hardiest for cooler climates. I still have 5 around my house, but sold a cluster of two 19 footers from behind my shop a couple of weeks ago.
Terry
Haven't checked this since I posted so a little update. The plants are in large pots and I have found a home for two at the middle school my oldest teaches at. They will go on a 2nd floor interior balcony. One will go to my mother's basement. Two will stay at our house to live in our garage until after Thanksgiving and the 40-50 guests leave. Then they will move to the sunroom. Gonna see how they thrive in different climates.
Hopefully my daughter will take four at the school but she has a brown thumb (every plant she touches dies) and I don't know how that will work out.
Thanks for the suggestions.
RSKY
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A57880)
2020 INTERNATIONAL...
2013 Fiat 500 Sport (A56859)
2013 Fiat 500...
Pallet of Vehicle Seats (A54816)
Pallet of Vehicle...
Hose Reel (A55787)
Hose Reel (A55787)
2017 International ProStar Truck, VIN # 3HSDJAPR4HN677698 (A57453)
2017 International...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
