Keeping the HTL Out Of The Way
   / Keeping the HTL Out Of The Way #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
The dealer came out today and installed 2 rear remotes on my TC25D. I left the HTL and hose kit I bought from CCI and they attached the hoses for me. /forums/images/graemlins/smile.gif I'm all set except for a way to keep the HTL out of the way when I am not using it. The HTL has a larger diameter than the standard top link and the top link hanger is too small. /forums/images/graemlins/frown.gif
For those who've added an HTL, what do you use to hold it out of the way? /forums/images/graemlins/confused.gif
   / Keeping the HTL Out Of The Way #2
I use a small loop of chain attached to the hook that was used for the manual top link. A rubber bungee cord would probably work also.
   / Keeping the HTL Out Of The Way #3
I used a bungee cord; kept thinking I'd make a good bracket, but never did.
   / Keeping the HTL Out Of The Way #4
First of all, Mike, CONGRATULATIONS!!! You're gonna love that HTL. /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif
Secondly, like Bird, I normally keep a bungee handy for securing the HTL. Since mine is made so it easily swivels from side-to-side (see adapter in attachment), mostly I just let it rest on top of the PTO shield while changing implements. I can pull it to the side, and it will clear so I can go up and over the implements toplink point.
   / Keeping the HTL Out Of The Way #5
Mike, I just re-formed my OEM top link holder rod to meet the new diameter. I found a scrap pipe roughly the same size, heated the rod, and gently ( hammered ) the rod to the new shape using the pipe as an anvil. I added a slight over bash to act kinda like a clip. It works well. I also adjusted the bend in the rod to make everything line up well. I've never had the HTL pop out when bounding over the hills and valleys /forums/images/graemlins/grin.gif.
Enjoy your new tool. I don't know why the factories haven't started adding them as OEM options. They are worth their weight in gold...( or should I say gasoline or steel these days )!
<font color="blue"> I found a scrap pipe roughly the same size, heated the rod, and gently ( hammered ) the rod to the new shape using the pipe as an anvil. I added a slight over bash to act kinda like a clip. </font>
This was the first thing that occured to me. I have a propane/MAPP gas torch, but I wasn't sure either one of these could get the rod hot enough. Then there's the matter of finding the right sized pipe to act as an anvil. /forums/images/graemlins/grin.gif
2014 CAT CT 660 Tandem Axle Dump Truck (A59213)
2014 CAT CT 660...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
10' Fork Extensions (A57149)
10' Fork...
2004 STRICK S75 53' VAN TRAILER (A52708)
2004 STRICK S75...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
PALLET OF FISHING GEAR (A58374)
PALLET OF FISHING...
