keeping mmm up
   / keeping mmm up #1
tinman565
Western NY
2005 NH TC33DA/Supersteer
Is there a way to keep the mmm in the up position while I use the 3 point hitch ? I just traded in my 1998 John Deere 855 for this blue thing that I'm falling in love with very quickly...lol. Its a TC33DA..15LA loader..supersteer..72"mmm. My JD was able to hold the deck up while using the 3 point hitch. Thanks.
   / keeping mmm up #2
I have the little brother to your tractor a TC-24D. If they are the same, there should be 2 pins in the tool box. You raise the hitch (and the MMM) up to the top, slide the 2 pins through the holes in the rear lift arms (attached to the MMM) and then put a hair pin to hold them in place. I'm not at home right now so I can't take any pictures to show you. But the hole should be near the location of the rear pins that hold the MMM on.
   / keeping mmm up
And thats it ? The other four pins stay in there where they are ? And while I raise and lower the 3 pt hitch..nothings gonna bind or snap ? So when I have it right, I should have a total of 6 pins holding my mmm in place ? Thanks.
   / keeping mmm up #4
Yep, that is it. The 2 pins you add will keep the arms from dropping down that the back of the deck is attached to. This will allow the 3-point lift arms to drop down "away" from the lift mechanism of the MMM.
   / keeping mmm up #5
Now that'd be handy! I'm going to see if I can do that with my TC18. I like to keep the deck on to lower my CG a bit... really hilly land!
Thanks!
   / keeping mmm up #6
And it does! I gotta get me a couple of pins, I'm glad y'all reminded me about that. Mowing season's just about over, it's time to start hauling wood on the carry-all!
Thanks again!
   / keeping mmm up #8
Yup, but I had to do what a fellow on another thread recommeded. Just try and find a 1/2" x 4 cotter pin in my neck of the woods. So, rather than another McMaster-Carr order for two pins, after the third hardware store with no success, I bought a pair of 1/2"x5-1/2 hex bolts, which will spend some time on my drill press this evening!
I also had to level the rear arms on the 3PH, they were 1 1/2" out. Which is surprising, because the guy that I bought it from was obviously very meticulous about everything else.
   / keeping mmm up #9
Be careful with the mower deck up in uneven ground or doing heavy loader work. You can put a lot of weight on the rear wheel assembly of the deck and bend it. Once I'm done with the mowing season I remove the deck to avoid damage and that way have a chance to look it over. Don't forget to look over the deck mount bolts to the frame from time -to-time also. Not a bad idea to remove the belt from the pulleys at the end of the season also to keep pressure off the bearing during off season.
   / keeping mmm up #10
Thank you sir, duly noted! I'll have a look at that geometry today!
I found it interesting that my homemade clevis pins were too short. It looks like they need to be 1/2" ~ 1" longer to go through all the holes in that bracket.
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
New/Unused 7ft 10 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 10...
2017 Land Rover Discovery SUV (A51694)
2017 Land Rover...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
