Keeping a battery charged
   / Keeping a battery charged #1
gunnner
Bronze Member
GRAHAM CO. N.C.--Elv. 3150'
Yanmar 1610 2X4 tractor---Kabota B 2320 4X4 7 Kobelco SK015 Excavator
The othe day I went to start my track hoe------Battery was dead---Have not used it for some time. As there is no power where I keep it I was able to jump start it with my tractor parked next to it.
So my question is: How often do I need to start/run my equipment to keep the battery up. Being that the batteries are around 2 years old ---how long do I need to run the engines?
   / Keeping a battery charged #2
It depends on the draw with the key off (is it computerized or have a clock or a radio?) and the temperature (cold is bad on battery's) and the cleanliness of the battery itself can cause a surface drain.
I use and highly recommend HF battery tenders I have them on everything I own that sits over the winter or is parked unused I realize you have no power but a small solar panel and a diode installed in the output of the tender I think would work.
   / Keeping a battery charged #3
A auto mechanic told my mom when she was having trouble with her car battery (she drove 2 miles to work and home only) that it takes at least 30 min driving at highway speed to re-charge a car battery after cranking. Apparantly she was not driving enough to keep the batteries charged so I rigged a trickle charger that would unplug if she forgot and backed out of the garage with it plugged up. That problem solved!
I have used Solar Charges and they seem to work well if you get the big ones from Auto suppliers and not the cheap small ones from Academy
   / Keeping a battery charged #4
One that would unplug is what I would need, soon as I had backed out I would remember it.
   / Keeping a battery charged #5
Yeah that sounds familiar :laughing: how about hanging the key on the battery tender wiring! :thumbsup:
   / Keeping a battery charged #7
I guess one could remove the battery alltogether and leave it where one could keep a trickle charger on it. Sounds like a lot of hassle, but might be better than starting/running the tractor just to keep the battery up.
   / Keeping a battery charged #9
I have some solar chargers. The small ones put out 100 milli amps and I have a big one that does 400 milli amps. I keep them one my vehicles. I also have a Noco genius battery charger that about once a month I use to top off the batterys. If you keep something inside I recommend you keep a quality battery maintainer on it. The battery in my truck is over 7 years old.
After thinkin bout solar chargers-------Well I don't get much direct sunlight up here-----perhaps in mid winter bout from 9AM till 2PM------so I now wonder if that is enough?????
Guess I could run a extention cord on the ground to the carport----after all I have other extion cords going to my lower carport , chicken coupe, garden shed ,& greenhouse ( parcially burried ).
2025 Wolverine TQH-26-02C 3 point hitch (A53117)
2025 Wolverine...
2024 KMC 7406 (A53084)
Unused 2025 Pure Electric Cart (A51694)
Unused 2025 Pure...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
