Eagleview
Veteran Member
2 Things , 1 is to make sure the loader is lowered to the ground and all hydraulic pressure is off of it before greasing . This will allow the grease to get around to the working side of the pins and bushes . If you don't , the weight of the loader will pull the bush hard against the pin and stop the ingress of grease to the point it most needs to be and it will take the easy route , the side that sees no action . 2 , Make sure the very end of the grease gun nozzle is half too one turn loose before you start , this will make it easy to remove so you don't break the nipple off .
