KE70 question
   / KE70 question #1
CanadianBeaverS370
Bronze Member
St-Telesphore,Qc
Satoh Beaver and IH B414 FEL
Hi Guys
Does any one have an exploded view of this engines assembly? The reason I ask is that I am looking for and access point to the water Jacket other than the temp sensor provision. I noticed on the lower side of the block between the starter and altenator there is a 3/8 ish bolt. I loosened it an it looked like coolant oozed out. I want to know if I can put my mechanical temp sensor there. I don't want to drain the rad just to find out... I looked for the provision on the water pump as stated by some other guys on this forum, unfortunately I could not us that port for my senor as it has a coolant line that goes to the bottom of the thermostat housing. Any help or advice is greatly appreciated :thumbsup:
BTW the KE70 is in a S370 beaver.
   / KE70 question #2
There is a point on the starter side of the block where you'd find what might be a drain plug. Forget what size it is.
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
2005 WhisperWatt DCA-70SSJU2 70kVA Towable Diesel Generator (A52377)
2005 WhisperWatt...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
HIGH-END MINI GOLF CART (A53843)
HIGH-END MINI GOLF...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
