ke130
/ ke130 #1
dalerick
mitsubishi d2000 II
Yes I have a mits,d2000 II ke130 2 cyl diesel water cooled .Does anyone know if there is any other engine that will bolt up on this tractor gas or diesel the starter is on the right side if you are sitting on it .Thanks Rick,:anyone:mur:
/ ke130 #2
Give Bruce Laten a call, he may be able to help you replace your existing engine or tell you an answer to your question. (931)492-0316
/ ke130
Thanks but dont think so He sent me a engine he said would work starter on wrong side that cost me $125.00 shipping and no offer to make it good.
/ ke130 #4
Hate to hear that. Did you ask about "making it good"? Can you give more details about what you purchased from him. Will the engine not match the bell housing, etc or is it strictly an issue with the starter being on left side? If the latter, does it prevent the engine from fitting in the frame?
/ ke130
He said he had a good engine on the phone i got it wont bolt up starter slot is in trans case could not even make plate to bolt to would have to push it off to crank
/ ke130
I have 2 cyl he sent 3 cyl hyd lines to short pump on wrong side
/ ke130 #7
Have to say, I like the guy and recommend him a lot but if he knew all the details about your tractor model, engine, etc. and said the engine you purchased would work and it doesn't as represented, I would be pushing the issue. Did you pay with a credit card by chance? If so and you can't settle the issue, you may have rights through the card company due to the Fair Credit Billing Act.
/ ke130
Not going to put him down but if someone ask i will lead them other ways.And i wasted to much time letting him wait on another box car of motors.I don't think he new as much about the Grey tractors as he lead on to.And i had to call him every time to see what he had found out.I think he called me one time in 30 days.With that said thanks for your time and trying to help.Rick
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
Front Tank Bracket (A64126)
Front Tank Bracket...
2022 EZ-GO ELITE...
