badapplefab
First I should state I'm generally cheap, and try to do most things myself, as I feel my time is free. When I bought my mule 610, I thought it would be helpful around the house/yard, and that it might be a way to do my driveway. I've always used a snowblower, but with a 450ft gravel driveway at the new house, I needed to make the switch to a plow. I had heard that a UTV works well to plow with, but still had never seen one in action. So as summer began to come to an end, I started looking for a plow for the mule. I came across a 4 way 54" hydraulic plow from a 400 series John Deere tractor for $325 on ebay. It came with the tractor side frame mount, plow and cylinders. Next came the job of mounting the plow to the front of the mule. It took a couple of nights of brainstorming, but I finally came up with solid, clean idea. My plan was to weld on some gussets to the front of the frame and weld a horizontal tube thru these gussets. And then pin the frame side plow mount to the tube, then I was going to run links back to the middle of the mule frame. I sleeved some holes so the links could just be pinned. In the end I had a plow that could be installed and removed by pulling 4 pins. The benefits of using this plow were, 1) it was cheap, 2) solid heavy duty plow with a trip feature, 3) it was hydraulic, and 4) it would be a good challenge. I still haven't gotten to hook up the hydraulics yet, still looking into ideas for a 12v power pack, anyone have any cheap ideas. So my current setup uses my winch to lift and lower, and to manually pivot the plow. I should also add that I incorporated my winch mount to the plow install mounts. Here are some pics, I will get some more when I get a chance. In the end I'm very happy with the install and how well it performed.
Gussets and horizontal tube
Sleeved holes in frame for aft links
Winch mount
Finish Install
Winch mount
Finish Install
