laurencen
- Joined
- Feb 19, 2007
- Messages
- 1,198
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
having issues with a Kawasaki Mule 610 drive, when stopping unless the shifter is in neutral it continues to creep, does not quite stall the motor but close if the brake is applied.
this is a new machine to me, it was a project so expected some work, took the belt off it was tight but is the correct one, the motor pulley is engaging and though slow it does release, took the driven pulley apart and the 3 plastic shoes are badly worn, on contacting the dealer there are 5 options, from 7.2mm to 7.8mm, measuring mine there is no where its close to any, dealer has no clue where to measure so anyone able to throw some light as to what this does?
next the manual shows the spring in hole number 2, there is 3 holes 1 thro 3, what does this change if number 1 or 3 is selected, it does change the shoe position relative to the cam and finally there are 2 bolts on the outside of the pulley, they thread in and protrude about 3 mm inside the housing, they contact a washer and hold the washer from sitting on the bottom of the housing, do they have another purpose?
seems these shoes are a couple weeks away, new shoes will prevent the pulley closing as much thus loosening the belt, just have to figure which ones to order
as usual any help is appreciated
