Kawasaki Mule 3010
   / Kawasaki Mule 3010 #1
nbrown
I am looking at buying a 2005 Kawasaki mule 3010. It wasn't running strong so the owner and I did a compression test and the rear cylinder was 100psi and the front cylinder was 50psi. He claims the compression is supposed to be 85psi but that sounds low to me. Does any one know what the compression is supposed to be?
   / Kawasaki Mule 3010 #2
Yes, the service manual says to run the engine until it is hot. Then, shut it off and remove BOTH spark plugs. Install the compression gage on a single cylinder and turn the engine over until the pressure gage quits rising (maximum cylinder pressure is achieved). The pressure should be 145 - 220 psi. Of course, you are not supposed to spray any liquid into the cylinders. Don't let a seller do that because it will give high readings that are false.
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
THE HANDLER II MIXER UNIT (A53843)
THE HANDLER II...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
1267 (A50490)
1267 (A50490)
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
