Kawasaki engine problem
   / Kawasaki engine problem #1
smstonypoint
Super Member
SC (Upstate) & NC (Piedmont)
NH TN 55, Kubota B2320 & RTV 900, Bad Boy Outlaw ZTR
I have a relatively new ZTR (with less than 70 hours of use) with a 31 hp Kawasaki engine (air-cooled 2 cylinder). When I was mowing 3 weeks ago, the engine lost power and backfired after 1.25 hours or so of use. I parked the mower for the night with the intention of staring at the engine the next day. ( I say "stare" because the extent of my mechanical knowledge keeps me from doing much more.:))
The next day, the engine started and ran fine as I finished up mowing for .25 hours or so.
I mowed again last week, and the same problem reappeared after mowing about the same amount of time (1.25 hours or so).
Am I way off base in thinking that I have a faulty ignition coil?
Thanks in advance for any help.
Steve
   / Kawasaki engine problem #2
check the vent on the gas tank,may be plugged.Maybe fuel starved after running a
while and then vents itself after sitting.
Dan,
Thanks for the info -- I will check the vent. Would a clogged vent cause the backfiring?
Steve
   / Kawasaki engine problem #4
think they had a recall on the fuel filter maybe check there
My problem turned out to be a faulty ignition coil. Per the recommendation of my local small-engine repairman (shade-tree variety), I had both coils replaced.
I have discovered that Kawasaki is very proud of its replacement parts -- $49+ per coil. OUCH!!!!!!!:(
Steve
   / Kawasaki engine problem #6
Thanks for replying with the cause of your problem
2018 FORD F150 (INOPERABLE) (A45333)
2018 FORD F150...
PALLET OF SAFETY FENCE (A45333)
PALLET OF SAFETY...
3 Pallets of Rock Climbing Wall (A42745)
3 Pallets of Rock...
2008 International School Bus Hood | OEM Quality Replacement | Fits IC Bus and More (A44789)
2008 International...
2001 WORKHORSE CONVERTED TO FOOD TRUCK (A43004)
2001 WORKHORSE...
1999 Volvo VN Truck, VIN # 4VA7BBJF3XN780047 (A44391)
1999 Volvo VN...
