Kawasaki Bayou 300 with no power
   / Kawasaki Bayou 300 with no power #1
Tanberry
N.W.Missouri
TC33DA
I have a 2001 KLF300 Bayou 4x4 . It has been an outstanding performer over the years dragging deer out of the woods and pulling a utility trailer around . Over the last year or so it's lost power . I really have to give it a lot of throttle to get it to start moving in forward or reverse once I get going it
feels like I'm in to high a gear . It's a 10 speed with a automatic centrifugal clutch . I guess I'll take to the Kawasaki dealer but thought I would check if anyone had an Idea if there some ajustment or somthing . I may even trade it on a new one ha . Thanks
Matt
   / Kawasaki Bayou 300 with no power #2
Matt
does it smoke?? you could look into a bore job and go one or two over and that would give you some more power and it would probably bring it up to a 350 range and it doesn't cost that much to do it .
   / Kawasaki Bayou 300 with no power #3
Sounds like the clutch is slipping. There is an easy adjustment that should be in the owners manual. Have you been using Kawasaki oil? I used regular oil once in the 300 I had 10 years ago and it made the clutch slip. JC
I will try and adjust the clutch. I have a manual but I didn't see it in there. It doesn't smoke and I've only used penzoil since it was new . Thanks
Matt
   / Kawasaki Bayou 300 with no power #5
I never believe eveything a saleman says, but when I bought my bayou 300, he said to only use kawasaki oil because regular oil would make the clutch slip. I used his oil for 3 years with no problem, but I went with regular motor oil after that. Not long after that the clutch started slipping. I sold it after not long after that to buy a bigger atv. JC
   / Kawasaki Bayou 300 with no power #6
Have you ever replaced the belt? Sounds like the belt is slipping
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2011 Nissan Frontier Pickup Truck (A53117)
2011 Nissan...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
