Kama TS354C Engine Running Rough
/ Kama TS354C Engine Running Rough #31
The tach adj was for Dwayne. .2 is good at idle, of course it will be higher above idle.
/ Kama TS354C Engine Running Rough #32
/ Kama TS354C Engine Running Rough #33
The last time I cleaned out the tank on my c/hi 695 I closed the fuel shut off and forgot to open it before I started the tractor. I go no power and lots of white smoke. As soon as I opened it, no problem. Maybe you have an obstruction
/ Kama TS354C Engine Running Rough #34
/ Kama TS354C Engine Running Rough #35
HAVE A KAMA TC354 QUIT WHILE USING --WAS IN SECOND GEAR UNDER LOAD PULLING DIRT QUIT NO WARNING-- HAS FUEL CAN PRIME UP WITH PLUNGER CRACK LINE AT INJECTOR -- SQUIRTS OUT OF EACH ONE -- SOUNDS NORMAL WHILE CRANKING ANY IDEAS
/ Kama TS354C Engine Running Rough #36
Try cracking one of the injector lines to see if it is squirting fuel, might have sheared key off the pump drive or something popped apart. You should also check if it has a fuel cutoff sol, it may have failed. If the engine shuts off with the key then yes it has some sort of electrical fuel cutoff. If it stays running until you pull a lever or rod then it is manual cut off and you may have broken something if you get no fuel squirt with a cracked injector line.
Remember you need fuel, air and Compression so if it has a Compression Release check that as well.
Mark
/ Kama TS354C Engine Running Rough #37
Thank u in advance--- cracked all four lines -- all squirt a small amout cant stop with finger so to speak but volume is low--did take injector pump apart and cam and pucks move up and down with the little push rod-so i dont know about pressure
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
Giyi Quick Attach 60" Mulching Head (A60463)
Giyi Quick Attach...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2017 Ram 5500 Bucket Truck (A61307)
2017 Ram 5500...
2011 Ford F-550 4x4 Terex Hi-Ranger LT38 38ft Insulated Bucket Truck (A61568)
2011 Ford F-550...
