kama km 554 steering
   / kama km 554 steering #1
gamefowlnut
The other day was driving down a gravel road. went around a curve to the right & had to turn steering wheel to left 3 complete turns to keep from running into ditch. i must be bleeding off somewhere, any help would be helpful!
   / kama km 554 steering #3
The steering cylinder is leaking by inside the cylinder, contact Chip at Artrac he has the rebuild kits in stock
Tommy
Affordable Tractor Sales
   / kama km 554 steering #4
Tommy
   / kama km 554 steering #5
Mine did that from day one. Chip sent me a rebuild kit but, just for grins I decided to drain the fluid. I got a lot of dirty oil out and refilled with 20 wt hydraulic fluid. It drives like a car at speed now. Before I couldn't keep it between the ditches. If you take the plug out of the bottom of the pump be careful, there is part of a valve in there that will fall out, watch to see which way it goes back in.
   / kama km 554 steering #6
   / kama km 554 steering #7
If there are no obvious leaks in the steering cylinder, try keeping the rpm's up and be sure your hydraulic steering reservoir is full (under the hood). I wouldn't think your cylinder is bad on a new machine?...but it happens.
   / kama km 554 steering #8
   / kama km 554 steering #9
They can leak across the piston without leaking externally. The oil just flows back with the return oil. It is a common problem on all chinese tractors. The easy test is if the steering wheel stops at the end of the travel or if can continue to turn.
   / kama km 554 steering #10
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
197711 (A51244)
197711 (A51244)
2012 Talbert Lowboy T(4)-55SA-BC-HBG (A52384)
2012 Talbert...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
2011 Nissan Juke SUV (A51694)
2011 Nissan Juke...
Year: 2015 Make: Ford Model: F-750 Vehicle Type: Truck Mileage: 79992 Plate: Body Type: Regular Cab (A51692)
Year: 2015 Make...
