KAMA Flywheel Housing
/ KAMA Flywheel Housing #1
3RRL
Super Member
Foothills of the Giant Sequoia's, California
55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Hi,
I need some help here with figuring out where to add grease related to this little sign on the right side of the flywheel housing (I think that's what it's called)...I'ts the housing right behind the engine but in front of the transfer case.
There are 2 rubber plugs and a sign that says to "pump grease into bearing periodically" What are they talking about?
I'll attach 2 pictures for anyone who knows.
Isn't that where the dry clutch assembley resides? Is there supposed to be grease or oil in there?
Thanks,
</font><font color="blue" class="small">( There are 2 rubber plugs and a sign that says to "pump grease into bearing periodically" What are they talking about?)</font>
Attached is a close up picture.
/ KAMA Flywheel Housing #3
There is a zerk fitting inside on the slide for the throw out bearing., it will work best with a rigid grease gun. This greases the slide for the throw out bearing to travel back and forth. don't overgrease it or you will end up with a lot of grease in the bellhousing (it would take a lot to get enough flying around in there to get into the clutch, but you dont want a greasy mess if/when you split the tractor.
</font><font color="blue" class="small">( There is a zerk fitting inside on the slide for the throw out bearing., it will work best with a rigid grease gun.)</font>
Thanks Chip,
Do I access this zerk through one of those holes covered by the rubber plugs then? Is that correct?
/ KAMA Flywheel Housing #5
yes, should be the plug by the little sign that says to grease here.
/ KAMA Flywheel Housing #6
Chip is correct. Pull the plug. I used my little pen light to see.
I did use a flex line but it would be much better with a rigid type
Patrick
</font><font color="blue" class="small">( yes, should be the plug by the little sign that says to grease here.)</font>
What about the rubber plug to the left of the one where the grease nipple is? Is there anything in THAT hole to grease? You can see it on the attachment in the very first post above.
Thanks,
Another question about greasing...
My KAMA book tells me there are supposed to be 4 grease nipples on the brake, clutch shaft assembly but I have yet to see them. I was told there may be greaseless bearings there, but I could not swear they are greaseless on my tractor....look like they need a zerk fitting. Am I looking at the wrong place or something?
Also, is there supposed to be a grease nipple on the rear hubs somewhere? Someplace to lubricate the rear axle bearings or something?
Thanks,
/ KAMA Flywheel Housing #9
nothing behind the other plug, just access inside the casting. No grease to rear axle bearings, they are massive roller bearings and lubed with the rear/trans oil.
There used to be zerks on the brake linkages, but recent tractors have not had them. The tractor comes with a grease gun with a pointy needle to lube these areas, but I agree a zerk would be better...
</font><font color="blue" class="small">( The tractor comes with a grease gun with a pointy needle to lube these areas, but I agree a zerk would be better...)</font>
Hmmm, I didn't get a grease gun...nor a tool box of any kind, or any spare parts. I even asked for the front ballast weights since they come with the tractor but never got those either. I know I don't need them with the FEL, but wanted to make fishing weights for my wife's coy pond.
What about those nifty looking front fenders on some of those internet pictures I saw? they look pretty cool.
/ KAMA Flywheel Housing #11
I thought the fenders were sharp also. Problem is they didn't work with a loader attached. I modified the brackets on mine to allow them to fit. Not that they are necessary but I thought they look cool! .... Scozz
/ KAMA Flywheel Housing #12
Check with your dealer. The hitch with the grease gun is that it will not accept a standard tube of grease, have to fill it by hand I guess, but it does have a pointly little tip, not zerk fitting but can greas zerk becauseit is small enough to go into the hole. We did not get these with all the tractors and the ones with zerks don't need it.
The weights don't come with tractors equpped with loaders normally, and they serve no function on the tractor. too expensive to ship after the fact, truth is they end up on a "scrap pile" although we have used a few for various ballast, I use one in my Ural sidecar if I don't have a passenger.
The fenders were disconitnued in early 2005 or late 2004 also we had to remove them if we installed a loader or reduce the turnging radius so the fender would not hit the loader brackets.
Metal American Flag Sasquatch (A65583)
Metal American...
Jeep Metal Tailgate Sign (A64557)
Jeep Metal...
2025 LandHonor LHR-SBC19 19 Gallon Portable Sand Blasting Cabinet (A64194)
2025 LandHonor...
2012 CLUBCAR GAS GOLF CART (A65054)
2012 CLUBCAR GAS...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2018 Ram 1500 4x4...
2018 International DuraStar 4300 26ft. Box Truck (A61573)
2018 International...
