3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,825
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Several questions for those who know.
My KAMA manual shift maintenance (every 8 to 10 hrs) refers to "checking the oil level in the Injection Pump Governor"...what does it mean and how do you do it? Is there a dipstick for it?
Where and how do you "Bleed the air out of the fuel system "? I figured out when cleaning the bowl it gets rid of sediment and water, I presume, but does that also let the air out? Dumb question but I'm confused.
The manual also says to "Grease (4X) the clutch/brake pedal shaft" but mine has NO zerk fitting on it? What's up with that? Should it have some there? Does it need it there and should I drill & tap and install my own?
I have a Koyker 195 FEL on it. Does it still need the front weights for balance/steadiness?
I found that when moving a heavy bucket full my power steering does not react. I turn the steering wheel but the wheels don't move. I had to lower the loader to take pressure off the front end and then was able to turn the wheels. It does not do this with lighter or no loads in the FEL.
Thanks, Rob
Thanks, Rob
