lakespirit
I need one on my 254, but never done one. Am I about to go off on a journey to never-never land? Any special tools required?
Nine maintenance items on the list.Engine, please.
This test only requires verification of delivery pressure. I interpret that as being pump output pressure. That can be done with that cheap diesel pressure tester that Harbor Freight sells. Other than that, it's a matter of cleaning the injector tips and visual evaluation of the spray pattern. If they can't be cleaned - or spray an inconsistent pattern - it would make more sense to simply replace them. Around here a professional injector rebuild runs ~$100 each, compared to <$200 for 3 new Y385 injectors.A good Bacharach test and calibration stand will run about $90,000.00. Best to send your injectors to a diesel shop for a pop & leak-down test. Much more reliable than DIY.
That's the engine manufacturer's 500 hour list - not mine. And if you don't think fuel delivery system maintenance and properly adjusted valves can help it start better, then somebody else must do your all your diesel maintenance work.Don't think doing any of those things on gregs list will help it start easier
Are you any relation to THINGY (without the .....,,,,,,,habit)?Well its still a motor and gears,thats what they all are,don't matter what brandNow if for some reason on a brand, this or that specificly was going bad at so many hours cause this hadn't been done,than yeah,it should be done.But just doing these things[which requires you to be a pretty good mechanic],for really no reason,is silly to me anyways.And probably causes about as much harm as good.Kioti don't tell you to get all that done,just get valves adjusted at 800 hours.Bet the rest don't either.Now,speaking of owners manual,brings me to thinking of warrenty. You need to do or get done,the things in book,to keep warrenty,which is just what you got to do. I;m betting the warrenty on his karma is long gone,so,no need to be bound by the owners manual,which makes me think,if he's even got an owners manual,cause he asked here.
Don't know why HF wasn't listing these at the time Bob. But a recent search ( http://search.harborfreight.com/cpisearch/web/search.do?keyword=fuel+injection ) did return fuel injection equipment. Whereas none of them specify diesel compatibility in the big print, there may be some more usable tech data in the individual product manuals.I checked Harbor Freight and all they had was a couple of diesel engine compression testers rated for 1,000 psig max., about half of what you will need (no fuel line adapters either). Or did you see a set somewhere else?
