Paddy
Veteran Member
Does any one have the procedures for adjusting the valve lash on the KAMA 454, engine Feidong 395 T. 3RRL had a nice procedure for the 4 cyc.
Patrick
Patrick
I agree, but make sure you lightly oil the threads and underside of the bolt head if you can get the bolt out all the way. Do only one at a time so you do not break the gasket set.3RRL said:Paddy,
What Jim said about cylinder numbering and finding TDC is correct. Rotate in direction of normal engine rotation. You can double check rotation by looking at the fins on your radiator fan too.
The head bolt re-torque is just that.... To make sure the head bolts are set at proper torque. Re-torque each bolt after loosening...mark the head and bolt first so you will see it rotates past it's prior position when you hit the proper torque. You can still follow the sequence for this procedure. I would torque them down in sequence if I removed the head without a doubt. This particular adjustment is to insure the head bolts are torqued correctly and should be fine to do it that way. Again, this is what I do and others may disagree.
Yea, there is some real Dandy's on that pathetic site. If you tell them you do this stuff for a living they get mad because they cant look good giving dumb advice anymore. It's usually the guys who can barely change oil in a lawn mower that seem to give the most advice on that site.tat2z1969 said:schmalts, one has to watch, I got kicked off a board for telling people to adjust valves that way (the correct way) and I have it posted on MY board that way, but I guess there are greater minds out there. I adjust mine same as you stated and have it posted as such where I know I won't get hung for saying it. Come to think of it, didn't you get crap on the same board because they thought you were me?
PA tractor forum - Login
schmalts said:Yea, there is some real Dandy's on that pathetic site. If you tell them you do this stuff for a living they get mad because they cant look good giving dumb advice anymore. It's usually the guys who can barely change oil in a lawn mower that seem to give the most advice on that site.
