Paddy
Veteran Member
Small issue.
My KAMA 454's tach is not reading constantly. Some times nothing, sometimes bouncing and sometimes reading correct.
I was told by the delivery guy that the sensor needs to be turned in a bit. He pointed to a device located on the bell housing located 6" up and over from the break pedal.
If this is the correct sensor, how far would you turn it in? It's a brass device with a jamb nut at the base.
Patrick
Patrick
