Price Check Kabota L3010HST
   / Kabota L3010HST #1
srxgreg
Oswego ny
New Holland TC45da
I am looking at a 2002 Kabota L3010HST with 72" mid mount mower tractor has 1750hr in very good condition always stored indoors. How much should I pay. Guy is asking 8700.00 usd
   / Kabota L3010HST #2
How much should you pay? What do they go for where you live? Does it have FEL? If I could have made that purchase here last summer I probably would have snapped it up. Personally I don't think it's unreasonable at all but I don't live in New York.
   / Kabota L3010HST #3
Kubota L3010
1998 - 2002 Grand L10 Series
Compact Utility tractor
Previous model: Kubota L2900
Next model: Kubota L3130
Manufacturer: Kubota
Variants:
L3010HST: 4WD Hydro
Kubota L3010 Engine:
Kubota 1.5L 3-cyl diesel
Kubota E-TVCS D1503 diesel
liquid-cooled
91.5 ci [1.5 L]
Bore/Stroke: 3.26 8x3.638 inches [83 x 92 mm]
Power (gross): 32.1 hp [23.9 kW]
Fuel system: indirect injection
Pre-heating: glow plugs
Rated RPM: 2700
Coolant capacity: 7.4 qts [7.0 L]
Capacity:
Fuel: 9.2 gal [34.8 L]
Hydraulic system: 10.3 gal [39.0 L]
3-Point Hitch:
Rear Type: I
Control: position control and optional draft control
Rear lift (at 24"/610mm): 2,200 lbs [997 kg]
Power Take-off (PTO):
Rear PTO: live
Rear RPM: 540 (1.375)
Mid PTO: semi-independent
Mid RPM: 2000
Dimensions
HST Weight: 2,745 lbs [1245 kg]
Wheelbase: 65.7 inches [166 cm]
Length: 110.8 inches [281 cm]
Width: 56.7 inches [144 cm]
Height (ROPS): 84.3 inches [214 cm]
Ground clearance: 13.8 inches [35 cm]
Front tread: 43.5 inches [110 cm]
Rear tread: 44.1/48.0/51.4/55.3 inches
[112/121/130/140 cm]
4WD turn radius: 8.2 feet [2.5 m]
Engine (gross): 32.1 hp [23.9 kW]
Engine (net): 30.4 hp [22.7 kW]
Gear PTO (claimed): 25.5 hp [19.0 kW]
Hydro PTO (claimed): 24 hp [17.9 kW]
Mechanical:
Chassis: HST - 4x4 MFWD 4WD
Steering: hydrostatic power
Brakes: wet disc
Cab: Two-post ROPS.
Hydraulics:
Type: open center
Capacity: 10.3 gal [39.0 L]
Pump flow: 7.0 gpm [26.5 lpm]
Steering flow: 4.7 gpm [17.8 lpm]
Page information:
Last update: December 28, 2018
Copyright: Copyright 2018 TractorData LLC
Contact: Peter@TractorData.com
   / Kabota L3010HST #4
With a Loader I would consider $8,700 a high value price in New York for a first iteration Kubota 'Grand L'.
The nearest equivalent in Kubota's product offering today is the L3301, which is not available with a mid-PTO but does have the advantage of an 'independent' rear PTO.
   / Kabota L3010HST #5
With loader I traded my 1300h (or so) L3410 with loader for 12k. That was after negotiation on the new machine, so I am sure the dealer planned on 14k reselling it.
The L3010 is slightly less HP, but even without a loader I would say $8700 is a good deal. Appearance is a plus, but that does not necessarily mean the machine is in good condition.
Also, pre emissions tractors are getting a premium price, and generally sell fast.
   / Kabota L3010HST
it doesnt have FEL all it has is 72"MMM and turf tires
2016 VOLVO VN SERIES SLEEPER (A50854)
2016 VOLVO VN...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
2015 International 4400 Cab & Chassis (A47384)
2015 International...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
