Kabota hoe drops
/ Kabota hoe drops #1
guyrich
Brentwood, New Hampshire
Kabota
Kabota LA1055 with BH92 hoe drops after a few hours of sitting. Getting worse. Hope someone has had this and point me in right direction.
Guy
/ Kabota hoe drops #2
some bleed down / drift is somewhat normal and can be expected.
caused by small internal leaks in seals of cyl or valvles, etc... Generally increases with age, use and/or abuse. I had a guy who seemed to keep pressure on too long when working after max. stroke had been reached and IMO his use would accelerate bleed down of my equipment.
solution is a rebuild of internal seals.
/ Kabota hoe drops #5
Kubota hydraulics are notorious for bleed down. I switched from UDT2 Hyd. fluid to the more viscous UDT and it helps a bit.
As mentioned above, use the boom lock on the BH92 and set the bucket of the LA1055 on the ground.
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A61574)
2017 Forest River...
2018 VOLVO SD115B PADFOOT ROLLER (A64279)
2018 VOLVO SD115B...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2019 John Deere R-4038 (A63688)
2019 John Deere...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
1995 John Deere 7400 (A60462)
1995 John Deere...
