Kabota hoe drops
   / Kabota hoe drops #1
guyrich
Brentwood, New Hampshire
Kabota
Kabota LA1055 with BH92 hoe drops after a few hours of sitting. Getting worse. Hope someone has had this and point me in right direction.
Guy
   / Kabota hoe drops #2
some bleed down / drift is somewhat normal and can be expected.
caused by small internal leaks in seals of cyl or valvles, etc... Generally increases with age, use and/or abuse. I had a guy who seemed to keep pressure on too long when working after max. stroke had been reached and IMO his use would accelerate bleed down of my equipment.
solution is a rebuild of internal seals.
   / Kabota hoe drops #4
next time buy a kUbota, they work better
   / Kabota hoe drops #5
Kubota hydraulics are notorious for bleed down. I switched from UDT2 Hyd. fluid to the more viscous UDT and it helps a bit.
As mentioned above, use the boom lock on the BH92 and set the bucket of the LA1055 on the ground.
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A52748)
Adams Load Out...
2011 Bobcat S630 Skidloader (RIDE AND DRIVE) (A50774)
2011 Bobcat S630...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
43016 (A51691)
43016 (A51691)
Bale Ring (A50515)
Bale Ring (A50515)
Miller Pro 5300 Silage Cart (A50774)
Miller Pro 5300...
