K800-3 wont start
   / K800-3 wont start #1
tbobinac
bobcat 753
Hello,
We have a mini kubota k800-3. It was running fine, than we went to start it and it won't turn over. It cranks and cranks but will not turn over. We have changed the fuel filter, air filter, glow plugs, starter, fuel, battery, and fuel solenoid. We have checked the lines to make sure the fuel is pumping through the lines. Any thoughts would be greatly appreciated.
   / K800-3 wont start #2
To make it easier for you..
Crank and cranks IS turning over..
U mean it cranks but won’t start..
Are u getting fuel thru the lines AT THE INJECTORS.?
Have u tried removing the shut off solenoid and trying to start it.??
Do u have fuel in the tank AND the fuel shut off valve in the run position.??
If yes to all this then, if u have fuel up to the pump inlet and nothing out, u have inj. pump problems..
2004 Toro Turf Sweeper 4800 (A50322)
2004 Toro Turf...
Turfco Mete-R-Matic III Pull-Behind Top Dresser (A51691)
Turfco...
2013 Ford F-650 Truck (A51692)
2013 Ford F-650...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2014 Volkswagen Jetta Sedan (A50324)
2014 Volkswagen...
Commercial Trailer (A51692)
Commercial Trailer...
