K46 Tranny
   / K46 Tranny #1
topstoy
Tonasket, WA
JD 2520 / Kubota KX121-3
So I have an appointment with the dealer to look at my X300 Tranny that is going bad. Thank goodness it is still under warrantee. Does anyone know if they will put the exact problematic type tranny back in or have they fixed the issues with the K46 and the replacement should last longer?
   / K46 Tranny #2
Haven't heard anything about changes or upgrades, haven't heard of them substituting synthetic oil either which would be better. Let us know how this works out for you.
   / K46 Tranny
Hopefully I can get 3 years out of the new one before I need to upgrade to the K66.
   / K46 Tranny #4
I upgraded to the k92 series and it better last awhile.
   / K46 Tranny #5
I've been doing a bit of research on the K46 as compared to the Hydro Gear T-2 (which Husqvarna just changed to in the past few months).
I have found a lot of threads around the various boards related to the K46 problems/performance failures being attributable to the need to change the oil after break-in (to remove the metal particulates from break-in), and periodically thereafter. Oil breakdown due to heat is the reason cited for issues. Of course, changing the oil is significantly impeded due to the tractor OEMs declining the $0.25 drain plug option offered by Tuff Torq, thus requiring removal and inversion of the transaxle in order to drain the oil via the filler on top of the case.
Some have also found the need to rebuild the cylinder blocks and center case as the cure for loss of power: https://www.tufftorqservices.com/EnvEEdefault/FlatHTML/TechInfo/help/helplosspower.html
   / K46 Tranny #6
Can't you pump it out like I do on my boat engines.
   / K46 Tranny #7
Best to change the scrawny little K46 out of the K66. Rebuilding a light weight K46 is a waste of time and money.
NEW HOLLAND C362 SKID STEER (A52705)
NEW HOLLAND C362...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
Galvanized Livestock Wire Gates (4X Gates) (A55218)
Galvanized...
City of Lakeland (A51691)
City of Lakeland...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
