OP
Short Game
Veteran Member
I appreciate the help though those are old links for me, as I am a veteran of this search. There are no short-blocks from what I can find. I can get everything except a block. I posted this thread because it seems about the only chance I have. I missed one on Ebay once, and it went off at a very reasonable price. I am on a small pension with nothing much for reserves. I will need a good deal to make it work out. I sure would like to have that Cub Cadet working for me again, as it was better in many ways than the 41 HP I have now, and far better on fuel. I have a bizillion hours in fixing that old machine and have learned pretty much how not to break it. I hate to see it sitting there.
If I can't fix it, I will put it back together and run it with the crack. It only gets water in the oil when it sits, so I can run it and drain the block and radiator every time. It gets lube oil in the water when it runs, so that will be the cost of doing business. Obviously, the crack is between the oil pump output and the water jacket, and apparently it is a small crack. The main oil gallery in the casting runs the length of the block along the right outer bottom corner of the water jacket, with a small line forward to the timing gears, and larger one to the rear. I don't know where else in the block there are pressure lines near the water jacket, so I assume that line in the casting is where the problem is. Water pumps should last well, running it that way.
