K3B engine timing--Shims?
/ K3B engine timing--Shims? #1
Farmall
Anyone know how to time a k3b mitsubishi engine? Is it shimmed and where could I get the right shims? This is in a Massey Ferguson 1120 tractor. When I bought this tractor I was told it needed an injection pump. It barely ran pouring black smoke when it was loaded in my truck. Since, I have not been able to get it to run.Supposedly the engine had been gone through, but it all seems suspect to me. Where can I get parts reasonably priced? I may need a rebuilt injection pump, injectors and probably glo-plugs, maybe a gasket set. Thanks for any help.
/ K3B engine timing--Shims? #2
You are not likely to find Mitsu parts reasonably priced. You may well not find them at all in the aftermarket. Case sold some as CaseIH compacts before the NH buyout. Maybe something there will cross over. But they never gave parts away, either.
/ K3B engine timing--Shims? #3
The K3B uses shims. I can supply you with new & used Mitsubishi parts.
John Deere Loader Frames (A63116)
John Deere Loader...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
1948 Willys CJ2A Jeep (A61166)
1948 Willys CJ2A...
2013 21ft Top Hat T/A Utility Trailer (A61569)
2013 21ft Top Hat...
UNUSED KJ 20'X30' METAL GARAGE (A62131)
UNUSED KJ 20'X30'...
2015 Ford Escape SVU (A61569)
2015 Ford Escape...
