K301S compression testing
/ K301S compression testing #11
What I do before I start on an engine repair is install shop air into the cylinder when the piston is up and the valves are closed, compression/power stroke. That gives you a heads up on where the compression is being lost,
It is called a cylinder leak down test, I add full shop air and if the air comes out the oil filler it is a ring problem, if it comes out the intake it is an intake valve problem, if it comes out the exhaust it is the exhaust valve, then you have to figure is it just the valves are to tight or what. I cuts down on unnecessary repairs, and misdiagnosis.
Just a thought!
2015 BOBCAT T770 SKID STEER (A62129)
2015 BOBCAT T770...
Bobcat 435 FastTrack (A60462)
Bobcat 435...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A59228)
2025 GIYI GY-SZYMJ...
2025 GIYI SE61 61in Sweeper Skid Steer Attachment (A59228)
2025 GIYI SE61...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
