K175 3 point stops lifting when mowing. Works again after cooling off. Oil looks airated.
   / K175 3 point stops lifting when mowing. Works again after cooling off. Oil looks airated. #1
gdcb
Sacramento, CA
kubota, zen noh
Old tractor, only used for field mowing before fire season and the occasionalpost hole. I replaced the PTO shaft and bearing last year and replaced the oil. Now the PTO stops working while mowing but starts working again after sitting a half hour or so. Oil looks aerated. I think it had too much oil. I believe I looked up the fill amount when I refilled it last year. Maybe there was oil still in the system and I over filled it? Is the plug on the left side by the clutch the fill level?
   / K175 3 point stops lifting when mowing. Works again after cooling off. Oil looks airated. #2
Sounds like air is being sucked into the hydraulics.
   / K175 3 point stops lifting when mowing. Works again after cooling off. Oil looks airated. #3
I believe you're referring to a Kubota L175 and not a K175? If that is the case, the oil has no effect on the PTO other that lubricating all the components. That tractor uses a single stage clutch for the drive and PTO.
If the PTO stops rotating, the tractor would also stop moving.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
UNUSED Battery Powered 3 Wheel Golf Cart (A55272)
UNUSED Battery...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59575)
1999 TRANSCRAFT...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
