K175 3 point stops lifting when mowing. Works again after cooling off. Oil looks airated.
   / K175 3 point stops lifting when mowing. Works again after cooling off. Oil looks airated. #1
gdcb
Sacramento, CA
kubota, zen noh
Old tractor, only used for field mowing before fire season and the occasionalpost hole. I replaced the PTO shaft and bearing last year and replaced the oil. Now the PTO stops working while mowing but starts working again after sitting a half hour or so. Oil looks aerated. I think it had too much oil. I believe I looked up the fill amount when I refilled it last year. Maybe there was oil still in the system and I over filled it? Is the plug on the left side by the clutch the fill level?
   / K175 3 point stops lifting when mowing. Works again after cooling off. Oil looks airated. #2
Sounds like air is being sucked into the hydraulics.
   / K175 3 point stops lifting when mowing. Works again after cooling off. Oil looks airated. #3
I believe you're referring to a Kubota L175 and not a K175? If that is the case, the oil has no effect on the PTO other that lubricating all the components. That tractor uses a single stage clutch for the drive and PTO.
If the PTO stops rotating, the tractor would also stop moving.
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2007 PETERBILT 379 (A52472)
2007 PETERBILT 379...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50775)
WE DO NOT...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
Heavy Duty Hydraulic 84" Broom  (A52384)
Heavy Duty...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
