K1 kerosene in tractor?
   / K1 kerosene in tractor? #11
From what I have studied you can burn
the straight kerosene however you will need to
add lubrication as its a pure fuel
I don't see why you would not be able to use a
50/50 blend with added lubrication
You will find some diesel engines can burn
straight kerosene don't know about the additives
Kerosene is a very good cleaner we used
to to clean engine parts instead of gasolene
If you get tar on your car kerosene will clean
it off very fast but wash after with soap & lots of
water.
willy
New/Unused Mini Crawler Dump (A54865)
New/Unused Mini...
Portable Restroom (A54865)
Portable Restroom...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A55302)
2003 International...
2006 SHOP BUILT 130 BBL STEEL VACUUM TANK TRAILER (A55745)
2006 SHOP BUILT...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
