JX95 Low Transmission Pressure light
   / JX95 Low Transmission Pressure light #1
Pkneibert
Leawood, KS
Case Jx 95
I have a 2008 JX 95 that I am wanting to use to run a PTO powered trailer pump. When I back the pump into the water and run the tractor, I'm getting the "low transmission pressure" warning light. The tractor is on a ramp with a 4 or 5 to 1 grade.
The dipstick indicates the reservoir is full.
I plan to run the pump for a couple days to flood a duck hunting marsh and don't want to damage the transmission.
Any suggestions or thoughts on how to resolve this problem?
   / JX95 Low Transmission Pressure light #2
Honestly, in a situation like this, the only real thing that you can do is check the pressure to make sure that it is right. Buying a gauge and a few fittings is all it usually takes. The angle that the tractor is on could be putting all of the fluid away from the pickup and causing it to suck some air instead of oil.
45050 (A51694)
45050 (A51694)
2015 Ford Expedition (A51694)
2015 Ford...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
PAIR DIAMOND PLATE DBL AXLE FENDERS (A51247)
PAIR DIAMOND PLATE...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
